July 17, 2008, 12:29 |
Air mixing, difficult question
Hello world,
I want to modelize mixing between two flows with a 2d model. The first one is a high pressure flow (30 to 100 psi, ie 2e5 to 7e5 Pa, positive x direction) The other one is low pressure flow (ambiant pressure, positive y or x direction, it depends mesh choice). I tried to use different viscosity models ( the best one seems to be RNG k-epsilon). Segregated or Coupled solver, the coupled seems to be the best even if convergence is hard (oblige to turn off equations, decrease numbers,...). But, I have a big problem, when i use : Display > path line i have not mixing between two flows. They are still segregated. I tried to use define > model > multiphase > mixture with regular settings but i have still same results. Have you an idea ? Everything happens as one flow can't penetrate the other one. The high pressure jet can drag along the low pressure gas but nothing else. Have you an idea ? |
July 18, 2008, 00:40 |
Re: Air mixing, difficult question
try to use species transport model.. then u can see the mixing of the two gases in the contours of mass fraction.. hope this may be useful...
July 19, 2008, 17:34 |
Thank you for your help
I fallowed your advice. But, because both of jets are air, the mass fraction is constant (=1) everywhere. Other Idea ? I will try to change one air stream for a benzene stream and check if the mixing happens. I don't need to take values on it but i want to be sure it occurs. Best regards. |
July 20, 2008, 10:30 |
i hope there will not be any mixing. its natural that high pr fluid will tend to drag the low pr fluid.isn't it?
See Fluent tutorial no.1. I think it is same as ur problem. |
Difficult ICEMCFD question: Extrusion | Walter | CFX | 11 | April 19, 2011 02:22 |
Whose programming is more difficult?DNS or LES? | Adonis | Main CFD Forum | 5 | January 6, 2006 16:23 |
cfx is Difficult to learn? | SAM | CFX | 3 | October 31, 2004 17:05 |
convergence difficult | Jason | FLUENT | 3 | May 20, 2004 12:13 |
Difficult BCs about Freesurface Simulation by VOF | Yongguang Cheng | FLUENT | 0 | September 19, 2003 07:39 |
