Turbulent Intensity too large!
Old   October 2, 2008, 12:25
Default Turbulent Intensity too large!
donde
Fluent's modeling of duct incompressible flow shows turbulent intensity about I=100-400% in regions closed to the walls, in the vortex wake after central body and outlet jet. Turbulence model is k-epsilon. Mesh is rather fine (y+=3). Pressure inlet and outlet conditions are set to I=1% and hydraulics diameter=2m.
Would you help me?
Old   October 2, 2008, 15:09
Default Re: Turbulent Intensity too large!
John S.
What kind of mesh are you analyzing?
Old   October 2, 2008, 21:00
donde
Mesh generating fragments:
'undo begingroup' 'blayer create "bl_virtual_wall_3" first 0.0001 growth 1.2 total 0.0186688 \' 'rows 20 transition 1 trows 0 continuous' 'blayer attach "bl_virtual_wall_3" face "face_throat_1" edge "virtual_wall_3"' 'undo endgroup' ... 'face mesh "face_throat_1" triangle size 1' 'face mesh "face_throat_2" triangle size 1' 'face mesh "face_before_grid" triangle size 1' 'face mesh "face_grid" map size 1' 'face mesh "face_after_grid" map size 1' 'face mesh "face_camera" pave size 1' 'face mesh "face_dif" map size 1' 'face mesh "face_outlet" pave size 1'
Old   October 4, 2008, 05:36
Friend
May I suggest that you have a look into the reference values used in calculating the intensity as that may give you a clearer meaning of what that intensity means in your model.
Old   October 20, 2008, 13:22
donde
Friend:
Thanks for the help!
Turbulent intensity and turbulent dissipation Phil FLUENT 2 February 14, 2018 05:06
Turbulent Intensity John Haynes Main CFD Forum 2 December 24, 2008 03:07
Specifying turbulent intensity ken FLUENT 6 June 2, 2005 02:50
turbulent intensity zwdi FLUENT 4 June 24, 2004 04:57
what is turbulent intensity? LG.P FLUENT 2 February 12, 2002 10:55
