how inport coordinate file in Gambit
Old   October 6, 2008, 22:52
Default how inport coordinate file in Gambit
ztdep
Dear friends:
I have a seris of points coordinate. i want to know how to import it into the gambit regards
Old   October 7, 2008, 01:47
Default Re: how inport coordinate file in Gambit
doki
well that's easy. you can import them as "vertex data" in the file/import menu of Gambit. note that coordinates for each point should contain x,y,z. even when the point set are 2d. also you should have the geometry coordinates file of just a set of coordinates like as: 0 0 0 1 1 1 4 3 2 ... (i mean nothing else should be written in the file) good luck
Is polar coordinate available in Gambit? David FLUENT 1 July 20, 2007 16:08
problem:tecplot inport fluent cas rener FLUENT 0 May 2, 2006 23:28
Gambit journal : how to find a vertex coordinate ? Cyril FLUENT 0 April 21, 2006 04:38
Gambit TUI : how to find a vertex coordinate ? Cyril FLUENT 0 April 20, 2006 04:29
Gambit: Text command to find a vertex' coordinate? Cyril FLUENT 0 April 19, 2006 11:17
