CAD & GAMBIT
Old   September 18, 2008, 07:19
Default CAD & GAMBIT
Kostas Pan
How i can design my geometry in Autocad and after i pass it the Gambit? It is needed to save the model which i make in Autocad, at concrete type of file?
Old   September 18, 2008, 07:51
Default Re: CAD & GAMBIT
wabik
Yes, in *.sat file
Brgds
Old   September 18, 2008, 09:01
D_Lichu
.igs should work too (in Autocad Mechanical 2007 works)
Old   September 20, 2008, 06:59
Madusuthanan
if you are geomentry in autocad is 3D then no problem you have to export your model in .Sat format from autocad and inport it to gambit. If you want to export 2d domains then you required help of third party tools like turbocad for exporting 2d domains to gambit as .sat file
Old   September 20, 2008, 08:22
doki
there are so many extentions which gambit is capable of handling. the .sat file is used for solid entities only! so for several solids there is recommended to use some other extention. IGS and other files can be used too! but it depends to the case.
Old   September 23, 2008, 11:31
Default Re: CAD & GAMBIT *NM*
Quoc
Old   October 8, 2008, 05:04
Mojtaba
hi I want to calculate "moment of inertia" in gambit. but it seems that gambit can not do this. can I export geometry from gambit to autocad? thank a lot
Gambit geometry creation: loading data to gambit C Ariyaratne FLUENT 10 March 17, 2011 16:39
Export data from GAMBIT to GAMBIT Sanjay Jain FLUENT 1 April 3, 2008 00:44
How to Import Gambit 2.2.16 file to Gambit 2.0.0 solomon FLUENT 0 January 4, 2007 14:49
