October 14, 2008, 15:11 |
What happen with the scale of pressure?
i have problem with the scale of static pressure of a flow.
it is show me big negative values of pressures. For example: In a pipe i put inlet pressure 40000Pa(approximately 0.4 atm) and outlet pressure 200000Pa(approximately 2 atm) and fluent show me values of pressure until -700000Pa (approximately 7 atm). How can it be occured this? If we have inlet pressure 0.4 atm then the minimum value can take the fluid is 0 atm. |
October 15, 2008, 03:48 |
Re: What happen with the scale of pressure?
The Inlet pressure you are giving is Static or Total Pressure ? is the same case for Outlet condition ? Did you check the Total/Static/ Dynamic pressure values after getting the solution ? you provided Pinlet = 0.4 atm, Poulet = 2 atm. in that case direction of flow will be completly reverse. In that Pinlet(0.4 atm is Total pressure) will be decomposed into two component:- Static Pressure & Dynamic Pressure. Please check those values. Are they give 0.4 atm by summing up Static & Dynamic pressure in the solution. I guess that will be helpfull, please fell free to ask if I can you help you in better way |
October 15, 2008, 05:24 |
hi devesh.
In the box of Pressure inlet of Boundary contitions there are two options: "Gauge total pressure" and "Initial gauge prssure". I use the second option for static inlet pressure. This is right? Still, i want to ask you, why is there the "operation condition". if i put a value of prssure in the operation condition, this value where will apply? I don't unstarstand where useful this. |
October 15, 2008, 06:05 |
Hi Kostas, Operating Pressure is Standard Pressure(i.e. 1 atm by default). Now what-ever pressure you put, that is Gauge pressure. You put 0.4 atm in Gauge Total Pressure (total pressure= static pressure + dynamic pressure).
Fluent works on Absolute Pressure(i.e. Operating pressure + gauge pressure). If you want to know more about Pressure , Please go through FLuent User Guide, that will help you alot. By chance if u want to run your analysis, you put 0.4 atm in Gauge total Pressure. "Initial gauge Pressure" is for initial guessing & is used in case of Compressible Flow. best of luck...... |
October 15, 2008, 11:16 |
Ok. i understand!
In the box of operating condition there are X: and Y:. What mean that? That on this point we will have the operation condition? If define aq point which find out of geometry what mean? |
October 16, 2008, 03:07 |
Hi, I think you are talking about Reference Pressure Location !....If you have been scaled your geometry & if this is not a very complex flow condition then leave it as default value of Zero.
If I am correct to understand your problem, then it is the location from where solver consider it as a reference point to adjust the Numerical Pressure with respect to surrounding cell centre. If I am misleading something, pls correct me. |
How could it (2D LES) happen? | Daniel WEI | Main CFD Forum | 7 | August 5, 2008 10:36 |
What will happen if | RKT | Main CFD Forum | 11 | October 15, 2007 00:59 |
Large Scale Model:Small scale computer | gull | COMSOL | 0 | March 5, 2007 06:37 |
Convert color-scale pictures to gray-scale ones | XC | FLUENT | 4 | March 29, 2005 18:55 |
What will happen | guanjian | Phoenics | 1 | September 19, 2001 14:38 |
