Help Reqd. - Doubt on Heat Transfer in FLUENT
Old   October 31, 2008, 06:58
Default Help Reqd. - Doubt on Heat Transfer in FLUENT
Sashankh
I need to analyze the flow of air over a tube through which water flows (heat exchanger element). The air heats the water. I have the inlet temperatures and velocities of both the fluids. I need to det the exit temperatures.
Pls guide me as to how i could assign the properties of the 2 fluids to the 2 boundary conditions in fluent. Do i have to choose a multiphase model (VOF)?
I really would appreciate any help regarding this.
Thanks! Sashankh
Old   November 4, 2008, 04:37
Default Re: Help Reqd. - Doubt on Heat Transfer in FLUENT
dev....
Hi shshankh.... As I undurstand your problem, water is flowing through the tube & air is passing outside of tube. Heat transfer is taking place from Air to Water. If I am correct, then you can difine two different fluid in Gambit itself & can give BC there. You must define the tube as solid & can give properties of solid in Fluent.
Old   November 4, 2008, 08:00
Sashankh
Hi Dev,
Thanks for the help. If I come across another doubt i'll post it here.
Thanks!
2D Heat Transfer problem in Fluent 6.3 please help Damian FLUENT 4 August 11, 2008 08:48
another 2D Heat Transfer problem in Fluent 6.3 Damian FLUENT 6 August 2, 2008 00:20
conjugate heat transfer in fluent mallika FLUENT 1 September 19, 2007 14:37
heat transfer with porous block in fluent salhi FLUENT 1 September 25, 2003 04:43
FLUENT heat transfer Chris FLUENT 4 November 24, 2002 01:17
