UDS Flux
Old   December 3, 2008, 04:25
Default UDS Flux
Thiru
Hello friends, I am using 4 User defined scalars in my simulation. I want to use user-defined scalar flux term. The following code which I found in the Fluent manual compiled fine but it is giving me error when I started simulation.
"Error: fluent.6.3.26 received a fatal signal (SEGMENTATION VIOLATION). Error Object: #f "
This UDS Flux function returns the mass flow rate to the UDS. Can any one please suggest me where is the problem.
DEFINE_UDS_FLUX(my_uds_flux, f, t, i) { Thread *t0, *t1 = NULL; cell_t c0, c1 = -1;
real NV_VEC(psi_vec), NV_VEC(A);
/* neighboring cells of face f, and their (corresponding) threads */
t0 = F_C0_THREAD(f,t); c0 = F_C0(f,t);
if (NULL != F_C1_THREAD(f,t)) /* Alternative: if (! BOUNDARY_FACE_THREAD_P(t)) */
t1 = F_C1_THREAD(f,t);
c1 = F_C1(f,t);
} else
t1 = NULL;
c1 = -1;
/* If Face lies at domain boundary, use face values; */ /* If Face lies IN the domain, use average of adjacent cells. */
if (NULL == t1) /* Alternative: if (BOUNDARY_FACE_THREAD_P(t)) */
NV_D(psi_vec, =, F_U(f,t), F_V(f,t), F_W(f,t));
NV_S(psi_vec, *=, F_R(f,t));
} else
NV_D(psi_vec, =, C_U(c0,t0), C_V(c0,t0), C_W(c0,t0));
NV_D(psi_vec, +=, C_U(c1,t1), C_V(c1,t1), C_W(c1,t1));
NV_S(psi_vec, /=, 2.); /* averaging. */
NV_S(psi_vec, *=, (((C_R(c0,t0) + C_R(c1,t1)) / 2.)));
/* Now psi_vec contains our "psi" from above. */ /* Next, get the face normal vector: */
F_AREA(A, f, t);
/* Finally, return the dot product of both. */ /* Fluent will multiply the returned value */ /* by phi_f (the scalar's value at the face) */ /* to get the "complete" advective term... */
return NV_DOT(psi_vec, A);
Old   December 4, 2008, 08:58
Default Re: UDS Flux
Thiru
One Update friends. When I deleted the density terms (C_R(c,t) and F_R(f,t)) it is working fine. Without density multiplication it becomes Volumetric flow rate. But if I want mass flow rate, I need density right?
About specified flux John FLUENT 0 November 13, 2008 05:37
ratio of total heat flux and radiative heat flux S.Karthikeyan FLUENT 2 July 1, 2008 03:48
WALL HEAT FLUX V.S. HEAT FLUX tommy CFX 0 December 15, 2005 08:14
Help with UDS FLUX Andrew Garrard FLUENT 2 February 14, 2005 05:47
Flux in UDS Ulrich FLUENT 1 May 30, 2000 12:37
