error running fluent 64 bit in kubuntu 8.1064-bit |
September 8, 2011, 07:20 |
Solved
#21 |
Paola Alpresa Gutiérrez
Rep Power: 14 |
@villager, this worked for me:
# sudo apt-get install ia32-libs together with adding to .bashrc the following lines: FLUENT_ARCH=lnx86 export FLUENT_ARCH alias fluent='(intalled_directory)Fluent.Inc/bin/fluent' export LD_LIBRARY_PATH=$LD_LIBRARY_PATHintalled_directo ry)/Fluent.Inc/fluent6.3.26/lnamd64/syslibintalled_directory)/Fluent.Inc/lib3.0/lnamd64 I didn't know that, even running on a 64bit architecture, you need 32bit lib for many things. Thank you all! |
[Netgen] Installation on Kubuntu 710 | sega | OpenFOAM Meshing & Mesh Conversion | 0 | September 20, 2008 11:04 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
FIDAP RUNNING ERROR "ERROR-DIR-NOT-EMPTY=145" | BAOYU | FLUENT | 0 | January 26, 2006 18:32 |
DPM running error! | x.p.lee | FLUENT | 0 | July 3, 2003 05:44 |
error while running UDF | murthy | FLUENT | 1 | October 22, 2001 05:02 |
