Pressure Inlet BC
Old   December 22, 2008, 12:32
Default Pressure Inlet BC
Prasad
Hi everyone,
I'm trying to simulate the flow around a building. I'm not simulating the entire height of the building, but only a portion in the middle.
I'm using the velocity inlet & pressure outlet BC's for the sides of the domain, and pressure inlet BC for the top and the bottom. I've set the static pressure to be equal to zero (free stream condition) for the pressure outlet. Therefore, I set the total pressure for the pressure inlet to be equal to the dynamic pressure based on the incoming flow velocity.
However, I'm having trouble with the convergence. Also, the static pressure along the velocity inlet is not equal to zero, even though freestream conditions are present there. I'm not sure if I'm specifying something incorrectly.
Thanks in advance, Prasad
Old   December 23, 2008, 08:34
Default Re: Pressure Inlet BC *NM*
mohamad
Old   December 29, 2008, 02:18
Milind Khedkar
Hi! I think this is 2D problem. Simulate in 2D only the cross section of the building and give Vin and Pout BCs. Lets try and hope your problem will get sorted out.
Milind..
Old   January 4, 2009, 22:55
Prasad
Hi Milind,
I'm trying to simulate the flow around a building with a velocity variation in the vertical direction (atmospheric boundary layer profile). Therefore, I need to run a 3-D simulation. Hope this helps. Thanks in advance,
Prasad
TKE & TDR in pressure inlet BC Sisir FLUENT 2 October 24, 2018 11:03
velocity inlet vs pressure inlet cheong FLUENT 6 April 9, 2011 03:07
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 18:20
BC for pressure inlet newbee OpenFOAM Running, Solving & CFD 1 July 5, 2006 05:21
How can I set the inlet pressure? moon FLUENT 7 August 19, 2003 14:17
