WAVE & TAB breakup inconsistency
Old   January 7, 2009, 11:02
Default WAVE & TAB breakup inconsistency
Orrin
Hi all,
I'm having problems regarding the particle breakup from a single injector source..
I am using unsteady tracking of particles being injected into a continous main flow. Particle breakup and collision are enabled under either the TAB or Wave model (the problem occurs with both).
Now, when I begin to iterate the flow, the injected particles break up as expected when they contact the main continous flow. They continue down the pipe as particles of smaller diameter than they were injected. After X amount of iterations however, the particle breakup halts and any newly injected particles pass through the domain without breaking. Given enough iterations, the particle stream will cease to break up and all particles in the domain will be of the same diameter giving incorrect performance.
I cannot pinpoint what causes the injection particles to suddenly stop breaking up upon entry as there are no time varying BCs. Is there a computational limit to the breakup models, or is this likely to be something else?
Any assistance would be most appreciated!
Inconsistency in CourantNoH rolando OpenFOAM Bugs 5 September 5, 2016 05:16
help me for"wave maker"&"wave absorber" bestrcsekhar Main CFD Forum 0 November 28, 2008 04:57
Inconsistency of GRidgen Prapanj Pointwise & Gridgen 3 September 30, 2007 15:08
Problem with BC inconsistency segersson OpenFOAM Running, Solving & CFD 5 April 28, 2005 12:34
Units inconsistency (CFX5.5) gilberto CFX 3 December 14, 2001 19:03
