New version fluent file open in Old version ?
Old   October 29, 2005, 03:29
Default New version fluent file open in Old version ?
MANOJKUMAR
Hi i am asking that if there is any option than the file in making in Fluent 6.2 is open in 6.1.18
Old   July 10, 2013, 04:12
FHydro
flow_CH is on a distinguished road
yes. i have this question. How can i open fluent 14 .cas file into fluent 12?
flow_CH is offline   Reply With Quote
Old   July 10, 2013, 04:43
blackmask will become famous soon enough
I have a vague impression that it is not supported.
If you want to make a case in v12 with the same settings as v14, you can check whether fluent 12 support the TUI command
/file/read-settings
If so, you can read the v14 case file and save the settings via
/file/write-settings some-yes-or-no-or-file-name-i-really-do-not-remember
Then start fluent v12, read the mesh file and use
/file/read-settings file-name-of-your-v14-settings
to read the settings.
blackmask is offline   Reply With Quote
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
