February 3, 2009, 03:41 |
conjugate heat transfer
Dear
I have two materials A and B each material has a thickness the computational domain is like a box and material A placed on the bottom face of the domain and material B placed on the upper face of the material A and there is an air flow from the left face of the domain to the right face of the domain over the two materials and there is a heat transfer between the air and the material A across the material B (Note: the width of the two materials is equal to the width of computational domain) May questions are: 1- after I draw the two materials inside and on the bottom of the domain as I mentioned, do I have to split the two materials from the domain or subtract or what must I do? 2- Do I have to mesh all faces of the domain, Material A and material B? 3- Do I have to mesh the volumes of the domain, material A, material B 4- Do I have to define each volume in the zones Type in Gambit? 5- How to define the heat conduction between material A and B in fluent? 6- Do you know any book or website or any thing that has details and solved examples simmilar to mine? I'm looking forward for your reply yours Thanks alot |
February 11, 2009, 09:04 |
Re: conjugate heat transfer
define everything as usual in gambit, after that
define the interface between two solids as a wall in gambit. while u export it to fluent it will create shadow on each side of wall, and it will couple it, u have to only define the material on the coupled faces. other things like heat transfer or temperature fluent will calculate. |
heat transfer in conjugate heat problems | cirilo | Siemens | 1 | April 18, 2006 09:16 |
conjugate heat transfer | Rabbit | FLUENT | 0 | October 18, 2002 00:32 |
Conjugate Heat Transfer- HELP! | H. Roy | Main CFD Forum | 1 | June 27, 2002 01:06 |
Conjugate Heat Transfer | A. Roy | Phoenics | 1 | June 26, 2002 18:35 |
Conjugate heat transfer | Kanghua Chen | Main CFD Forum | 15 | October 11, 1999 14:59 |
