March 12, 2009, 17:15 |
UDF problem in multiphase model
Dear all I am working on modeling a solar still in which water enters from below then evaporate and condense at the top. I have some problem with udf,which is needed to model condensation at top. I use the one in the help which name is liq-gas in multiphase MACRO example-udf section do you have any idea for a udf or I can use something else? thanks
March 13, 2009, 08:43 |
Re: UDF problem in multiphase model
I want to write a udf that I can model phase change for example something like this if T>T_SAT then phase1 change to phase 2 else phase 2 change to phase one I think I should write it sooner any ideas?
Viscous model problem with bubbles in multiphase | Shin | FLUENT | 0 | March 10, 2008 17:31 |
problem with MFR model for multiphase mixing tanks | Srinivas | Main CFD Forum | 1 | November 7, 2005 14:16 |
multiphase mixing Problem with MRF model in MixSim | Srinivas | FLUENT | 0 | October 17, 2005 06:35 |
multiphase model | Sumeet | FLUENT | 2 | August 31, 2005 08:26 |
Problem of B.C. in Eulerian multiphase model | Derek Jing | FLUENT | 0 | May 12, 2002 11:52 |
