March 13, 2009, 07:18 |
how to open a cas file in gambit
hello, i lost my gambit file but i have a .csa file, how can i get my mesh back from thet file. Thanx for your help
March 13, 2009, 08:41 |
Re: how to open a cas file in gambit
First of all I consider .cas not .csa (I don't know if csa is a valid extension) go to FILE-->IMPORT-->MESH--> and change the format from ANSYS to fluent 5/6
if you have .jou file you can load journal too which gambit redo what ever you have done I think this will help |
March 13, 2009, 08:55 |
thanx i will try that
March 13, 2009, 13:05 |
Search the forum, this topic has been covered many times.
Good luck, Jason |
March 13, 2009, 13:54 |
Re: how to open a cas file in gambit *NM*
Sorry, responded to the wrong thread (must've hit the backbutton too many times)
Thanks Jason |
March 14, 2009, 16:37 |
you can import the mesh file into gambit and i am not sure about .cas file. also, after importing, you will see virtual geometry.
How to open mesh file in Gambit /pls help | FRAJ | FLUENT | 14 | February 19, 2017 01:36 |
[GAMBIT] Gambit to open and old msh file | Muntasir | ANSYS Meshing & Geometry | 5 | August 2, 2012 02:21 |
Gambit error on linux: Unable to open file ... | Wim Heirwegh | FLUENT | 1 | October 10, 2007 11:06 |
How to open .SAT file by GAMBIT? | Ertan Taskin | Main CFD Forum | 2 | September 25, 2007 08:35 |
how to open .cas file in gambit? | revathi | FLUENT | 4 | August 16, 2007 01:28 |
