March 27, 2009, 07:52 |
gas hold up/gas volume fraction
chaker rym
Rep Power: 17 |
can any one please tell me about the difference between gas hold up and gas volume fraction.
regards |
May 7, 2009, 13:58 |
Sandeep
Rep Power: 17 |
Typically hold up is termed for liquids.
May be gas holdup = 1-liquid holdup. Anyways, input GVF= Q_g/(Q_g + Q_l). It is based on the flow rates. It gives an idea on the area fraction covered by the gas, liquid if both are moving with same velocity. But, if there is slip, the gas tends to move with higher speed than the liquid. During this time, the in-situ volume fractions for both phases will be very different. because, gas occupies less area than the liquid due to mass conservation principle.Typically, liquid holdup is calculated using emperical correlations. Regards, sanbhat |
May 7, 2009, 18:02 |
chaker rym
Rep Power: 17 |
Thanks...
regards CHAKER |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
