April 13, 2012, 11:32 |
Periodic Boundary condition.
AHMAD
Hi.
I have a problem in making a periodic boundary condition, it happens when i try to make my mesh finer. fluent gives me this Error. Warning: differing number of faces on these threads. computed translation deltas: 0.100000 -0.000126 zone 20016: matched 83 out of 83 faces. zone 30021: matched 83 out of 84 faces. Error: Failed to make zones periodic. Error Object: #f Thank you. |
April 16, 2012, 05:16 |
Rep Power: 14 |
with what software did you build your mesh? Using ICEM? Have you checked your mesh for errors? What did you obtain?
April 16, 2012, 21:32 |
#3 | |
Lucky
Rep Power: 66 |
It looks like you are using auto compute. Are the translation deltas even correct? Try to input the translation vector manually, it helps. If that doesn't work, most likely it is a meshing problem. |
April 17, 2012, 02:30 |
#4 | |
AHMAD
Thank you for your replies,
My problem was because of using a conformal periodic bc, so when i used a non-conformal periodic bc it worked out. Thanks to banty. Quote:
April 17, 2012, 06:39 |
Lucky
Rep Power: 66 |
periodic boundary condition in LES | martor | FLUENT | 3 | April 30, 2022 00:20 |
mixed inflow/outflow downstream boundary condition question | peob | OpenFOAM Running, Solving & CFD | 3 | February 3, 2017 10:54 |
periodic boundary condition (translational) fluent 6.3 | haihek | FLUENT | 3 | January 22, 2014 04:10 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 02:53 |
translational periodic boundary condition | Rola Afify | FLUENT | 2 | September 12, 2006 08:39 |
