plane Poiseuille configuration, please your help
Old   April 15, 2009, 08:02
Question how to simulate plane Poiseuille configuration
gina
gina is on a distinguished road
I have tried to reproduce the plane Poiseuille configuration (100*2) m in Fluent, I have to compare laminar and turbulent test case with DNS data.
I have begun with laminar 2D test case (Re_m= 5400), I specified the boundary condition as follows, at the inlet à velocity = velocity magnitude = 30 m/s (in x direction), at the outlet à zero pressure outlet, at the top and back wall à no-slip stationary.
After running, the profil is not parabolic!
Could anybody please explain what went wrong?
thanks a lot.
gina is offline   Reply With Quote
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Requesting plane properties: DEFINE_DPM_OUTPUT Julian K. FLUENT 0 December 21, 2008 05:44
ICEM and symmetry plane Roland CFX 3 September 13, 2006 08:38
creating plane with text menus Jenifer FLUENT 0 May 20, 2005 15:41
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
