Macros for discrete ordinate, non gray model
Old   January 23, 2012, 04:54
Default Macros for discrete ordinate, non gray model
yashmash is on a distinguished road
Hi all,
I am using the discrete ordinate, non gray radiation model. I am after the macros to access the incident radiation for each band and the absorption coefficient for each band as well.
Anyone able to assist?
Thanks!
Yash
yashmash is offline   Reply With Quote
Old   March 19, 2012, 02:13
Ali Emadi
aliemadi is on a distinguished road
Hello Yash
you can access to Incident radiation of each cell by using the following macro(in DOM):
C_STORAGE_R_XV(c,t,SV_DO_IRRAD,i)
where i is the number of grey band and you can change it from 0 to the last band.
you yourself define absorption coefficient for each band! so you obviously know its value. If you want to define not a constant absorption coefficient for each band you can use it's standard macro:
DEFINE_GRAY_BAND_ABS_COEFF(name,c,t,nb)
as an example:
#include "udf.h"
DEFINE_GRAY_BAND_ABS_COEFF(user_gray_band_abs,c,t, nb)
real abs_coeff = 0;
real T = C_T(c,t);
switch (nb)
case 0 : abs_coeff = 1.3+0.001*T; break;
case 1 : abs_coeff = 2.7 + 0.005*T; break;
return abs_coeff;
good luck
Ali
aliemadi is offline   Reply With Quote
Atomization and Breakup model xck1986 OpenFOAM 4 May 31, 2014 04:43
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
Discrete Ordinate Model Raffi Kazazian Main CFD Forum 1 January 4, 2000 02:25
