MULTIPHASE - FREE SURFACE & MIXTURE MODEL
Old   November 17, 2004, 10:21
Default MULTIPHASE - FREE SURFACE & MIXTURE MODEL
Aris
I try to model the flow into stratified sea. The cause for the stratification is the difference of the salinity. As I know, in Fluent I can't use the salinity as a parameter and calculate the density as a function of the salinity (and secondary of the temperature). So, I have thought to use the multiphase mixture model with two phases of liquid, (for example one with density 1010 and one with density 1025 kg/m3) and choose as initial condition the fraction of the two phases as a function of the depth.
On the other hand, the model requires free surface, so I need to use air as an additional phase including the VOF model. The conflict is that I can't use the VOF model and the mixture model simultaneously.
Any idea?
Old   November 18, 2004, 09:50
Default Re: MULTIPHASE - FREE SURFACE & MIXTURE MODEL
Tanja
You could try to use a UDS to describe the concentration of salt in the water. Then you can calculate the density of water depending on the value of the UDS in each cell by means of a simple UDF.
This way you don't have to use the mixture model, and you can use the VOF model for your water-air surface.
Old   November 19, 2004, 04:01
Aris
This is exactly what I need. Thanks a lot.
Old   April 28, 2009, 11:46
Default salinity
anissa ghomrassi
anissa is on a distinguished road
i want to know exactly how to enter the salinity
anissa is offline   Reply With Quote
Free surface or Mixture Model ? Hervé CFX 10 December 29, 2014 13:29
How to include lift forces/wall lubrication forces in the MIXTURE multiphase model? hohomm FLUENT 0 December 17, 2009 05:45
Free surface flows and multiphase flows Vidar Main CFD Forum 0 September 18, 2008 05:05
Boundary condition of free surface model Tony FLUENT 3 September 27, 2004 13:48
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
