Which Heat transfer coeffcient to use?
Old   May 1, 2009, 12:45
Default Which Heat transfer coeffcient to use?
tengra is on a distinguished road
Hi folks:
Lets say we simulated a turbulent pipe flow by using standard k-epsilon model with one of the wall function (lets say standard wall function). Now we need the heat transfer coeffcient on the pipe surface as output from this simulation. In FLUENT under wall fluxes menu there is "surface heat transfer coefficient" and another one called "wall function heat transfer coeffcient". My questions are:
(1) which heat transfer coefficient (from the above 2) I should take as output from FLUENT?
(2) Lets say another person did the simulation of the outer domain of the pipe, in that case if he wants to give me the heat transfer coefficient which one will he give to me?
Thank you guys.
T
tengra is offline   Reply With Quote
Old   May 1, 2009, 13:49
Ralf Schmidt
Ralf Schmidt is on a distinguished road
Hi!
the "wall function HTC" is calculated directly with the law of the wall. This is described in the Fluent manual as well.
Use the "surface HTC" - this one is calculated with the heat flow and the reference temperature. So you have to set the reference temperature as your fluid temperature.
Best wishes
Ralf
CFD - nothing but Colourful Fluid Dynamics
Ralf Schmidt is offline   Reply With Quote
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Heat transfer coeffcient Raj FLUENT 7 April 9, 2009 20:30
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 09:25
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
