Mass flow rate in a 1/4 pipe (periodic boundary)
Old   April 30, 2009, 14:15
Question Mass flow rate in a 1/4 pipe (periodic boundary)
allamarein is on a distinguished road
If I draw only 1/4 of the real inlet of the pipe (I use periodic condition and I study only a "V" domain), I have to set 1/4 of the mass flow rate?
allamarein is offline   Reply With Quote
Old   May 1, 2009, 00:16
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
yes.
But you can use also the symmetry BC
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 1, 2009, 09:28
sourplum
sourplum is on a distinguished road
Send a message via Yahoo to sourplum Send a message via Skype™ to sourplum
I think better u use symmetry BC. U can find the tutorial here
Best regards,
sourplum
sourplum is offline   Reply With Quote
Old   May 1, 2009, 14:41
You are right.
I've not specified that I have 4 radial injection flows equally spaced, so I used a periodic boundary condition (and not symmetry)
I set periodic boundary conditions with 0 pressure gradient
boundary condition, mass flow rate, periodic
Mass flow rate and periodic boundary allamarein FLUENT 2 April 21, 2009 05:21
Reg Mass flow rate jksanil CFX 1 January 6, 2009 03:08
How can apply mass flow rate boundary condition? Sima Phoenics 1 December 1, 2007 18:55
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 07:17
Mass flow rate through a valve Martin Sigrist FLUENT 1 December 8, 1999 15:00
