gas hold up/gas volume fraction
Old   March 27, 2009, 07:52
Default gas hold up/gas volume fraction
chaker rym
CHAKER is on a distinguished road
can any one please tell me about the difference between gas hold up and gas volume fraction.
regards
CHAKER is offline   Reply With Quote
Old   May 7, 2009, 13:58
Sandeep
sanbhat is on a distinguished road
Typically hold up is termed for liquids.
May be gas holdup = 1-liquid holdup.
Anyways, input GVF= Q_g/(Q_g + Q_l). It is based on the flow rates. It gives an idea on the area fraction covered by the gas, liquid if both are moving with same velocity.
But, if there is slip, the gas tends to move with higher speed than the liquid. During this time, the in-situ volume fractions for both phases will be very different. because, gas occupies less area than the liquid due to mass conservation principle.Typically, liquid holdup is calculated using emperical correlations.
Regards,
sanbhat
sanbhat is offline   Reply With Quote
Old   May 7, 2009, 18:02
chaker rym
Thanks...
regards
CHAKER
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
