mixing flow
Old   May 11, 2009, 03:44
Default mixing flow
kikimon is on a distinguished road
The model is basically a large diameter duct with a thin injection tube on the side (T-shape with 2 inlets and 1 outlet). After running the sym, the air speed at the interior goes to the order of 10^16 m/s! During the first iterations, the speed starts going crazy at the inlet of the small tube. Afterwards the whole system has this unrealistic velocity gradients. The inlets speeds are supposed to be around 15 m/s and I`ve tried for boundery conditions the "velocity inlet" and "pressure inlet". I`ve also tried refining the mesh and using various turbulance models. I was hoping to get something close to laminar flow (15m/s) at the center of the tubes. I`d appreciate it if you have any idea of what`s causing this problem .
kikimon is offline   Reply With Quote
Old   May 11, 2009, 10:40
zhao peng
zhaopeng is on a distinguished road
How did you set the outlet boundary?
zhaopeng is offline   Reply With Quote
Old   May 11, 2009, 18:37
zhao peng, thank you for your reply.
I set the outlet boundary as a pressure outlet, with stagnation pressure of 1atm
Old   May 12, 2009, 01:10
zhao peng
what is the pressure differential between major inlet and outlet?and is the air compressible?
Old   May 12, 2009, 01:59
Between the inlet and outlet of the large pipe is 135 Pa and the gauge total pressure of the injection inlet is 540 Pa. This way I got a initialization speed of 15 m/s in the large duct and 30m/s in injection tube.
Thank you again.
Old   May 12, 2009, 19:29
I forgot to mention I`m treating it as incompressible beacuse of the low speed of the airflow.
Old   May 12, 2009, 21:55
Martin Gariepy
martingariepy is on a distinguished road
Dear kikimon
There is something wrong with your boundary condition and/or operating pressure. The veloity you obtain let me think about a pressure differential between the inlet and oulet of around 100000Pa. What might happen is this:if you set your operatiing pressure at, let say 101325, then you should set all the pressure as gauge pressure, then your outlet pressure will be zero and the inlet pressure will be 0+delta_P where delta_p his suppose to be the pressure differential that you want beetween the inlet and outlet.
Hope it's help
Martin
martingariepy is offline   Reply With Quote
Old   May 13, 2009, 02:31
Thank you Martin for your response. I did set the outlet pressure as 0Pa and took into consideration the gauge term. Anyway, the problem is solved, it was the solver equations I was using. I ran 40 iterations with simple-standard and 100 more with coupled-second order and finally got it to converge with reasonalbe quatities. It might be something I should`ve known, but this was the first all-by-myself fluelnt sym, thank you both for your answers.
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Gas flow profiles in mixing tank srinivas FLUENT 0 November 8, 2006 04:52
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Boundary Layer Flow Paradox Wen Long Main CFD Forum 3 September 24, 2002 08:47
