Question about XY Plots
Old   May 19, 2009, 13:27
Default Question about XY Plots
Iaroslav
Iaroslav is on a distinguished road
Hello everyone,
I am attempting to make an XY plot of Relative Mach Number vs. Diameter Length (where D=7.3mm). I am able to set relative Mach Number for the Y function, but the only thing I can do with X-Axis is set it to standard length along the axis (in meters). Is there any way to change the meters to diamter lengths (my domain is already scaled approptiately using the factor 0.0073).
Thanks,
Iaroslav
Iaroslav is offline   Reply With Quote
Old   May 20, 2009, 04:27
Max
coglione is on a distinguished road
hello Iaroslav,
have you tried to deactivate the button "position on x-axis"? If deactivated you can plot any variable on the abscissa, e.g. radial coordinate which may be what you need.
cheers
coglione is offline   Reply With Quote
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
Vector Plots Question Jason FLUENT 1 November 17, 2004 19:34
drawing of contour plots chinthakindi Main CFD Forum 1 April 27, 2004 04:33
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
question K.L.Huang Siemens 1 March 29, 2000 04:57
