Catch rate(gm/in2), in DPM
Old   June 5, 2009, 13:13
Default Catch rate(gm/in2), in DPM
Saima
Saima is an unknown quantity at this point
I have a problem in which a heater is on leading edge of an airfoil and this airfoil is placed in Icing wind tunnel. Air is inside the tunnel at -5C. And water spray by using atomizer is also there.
I want to calculate the catch rate of droplet on the leading edge of Airfoil.
(that means how much droplet impinge on leading edge)
I know, we can determine the Concentration(Kg/m3) but i don't know how to calculate Catch rate(gm/in2).
Can anybody help me.
Thanks in Advace!!
Regards,
Saima
Saima is offline   Reply With Quote
Old   June 26, 2009, 07:18
nat
nat
nat is on a distinguished road
Hi Saima,
I have as well the same probleme... Did you find a way to calculate the local catch efficiciency using DPM.
To calculate the catch efficiency over an airfoil I use to export the droplet trajectories to a spreadsheet and then after a bit of data post processing I obtain the local catch efficiency curve. I am looking for a more straightforward method.
Thanks,
Nat
nat is offline   Reply With Quote
DPM and LES R.Sripriya FLUENT 6 April 15, 2017 04:41
DPM post proc problem Stel_K FLUENT 1 March 27, 2009 09:42
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 11:58
slow after mesh for enhanced wall treat DPM joshkemp FLUENT 0 May 1, 2007 17:20
compatibity LES with DPM Alex Munoz FLUENT 0 March 26, 2003 21:13
