Low under relaxation factor
Old   June 11, 2009, 00:01
Default Low under relaxation factor
sm
swati_mohanty is on a distinguished road
Dear all,
i am running a VOF model for air water system and find that the residuals for the continuity equation do not converge using default under relaxation factors. I have changed the under relaxation factor for momentum to 0.01 and find that the convergence is much better. However, is it advisable to use such a low URF.
Thanx in advance
SM
swati_mohanty is offline   Reply With Quote
Old   June 11, 2009, 08:13
Piotrek is on a distinguished road
dear swati,
By lowerign URF to such a low value, you limit any chance for the results to change. It makes in difficlut to estimate if the results are changing and you need considerable number of iteration to pass in order to see any influence.
I suggest lowering UDF gradually. Starting from default value and lowering by about 10-20% once the residuals are stable - not changing.
If you see no change in relevant variables on chosen surface, after a number of iterations you can judge, that the run is converged.
Hope that helps/
Piotrek is offline   Reply With Quote
urf, vof
what is under relaxation factor? rayy FLUENT 30 September 6, 2020 01:06
help in relaxation factor SONALI FLUENT 5 August 11, 2005 20:27
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 14:37
Relaxation factor Moon Siemens 1 June 13, 2003 11:13
