Fluent 12.0
Old   May 26, 2009, 07:28
Default Fluent 12.0
cinmar is on a distinguished road
Hi guys,
I am trying to use the new version of FLUENT 12.0....that is incredibly slow!!
has anyone experienced the same??
Thanks
Cinzia
cinmar is offline   Reply With Quote
Old   May 26, 2009, 10:43
Kestas
Kestas is on a distinguished road
I'm using Ansys products v12, including FLUENT 12. Speed is good.
But there are big bug:
I see no 2D regions i specified using CFX mesh, when i run fluent 12 from ansys 12 workbech project!
So i am using a trick:
I create mesh and specify 2D region names in ANSYS v11 workbench CFX mesh, save mesh file for FLUENT and open it with Fluent v12
Do you have such problem? or are you using gambit to create mesh?
Kestas is offline   Reply With Quote
Old   May 27, 2009, 19:57
Default Fluent 12 Performance - Named Selections
Kambiz
kamnaz is on a distinguished road
Cinzia:
I am using Fluent 12 (release version not beta) and it works really well. Provide more information on your computer/Fluent setup. I also using it on a Microsoft HPC cluster and am extremely satisfied with the performance.
Kestas:
That is not a bug. You need to use Names Selections in Workbench meshing for 2D surfaces (inlets/outlets/walls etc). Try import the mesh into a Workbench Mesh Component, add the Named Selection in there and then import it into Fluent.
-Kambiz
kamnaz is offline   Reply With Quote
Old   May 29, 2009, 12:21
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
The speed is good but the user-interface.... BAD WORK people from ANSYS really bad work....
Philipov is offline   Reply With Quote
Old   June 12, 2009, 04:56
Kestas
thanks, kamnaz, it worked.
Philipov, what is bad?
Old   June 12, 2009, 06:14
Philipov's Avatar
Svetlin Filipov
With trying to incorporate ANSYS interface type to FLUENT, the final product is not very good and the short definition is bad.
bad (vs. good)
atrocious, abominable, awful, dreadful, painful, terrible, unspeakablecorked, corkydeplorable, distressing, lamentable, pitiful, sad, sorryfearful, frightfulhard, toughhopelesshorridicky, crappy, lousy, rotten, shitty, stinking, stinkyillincompetent, unskilledmediocrenaughtynegativepoor
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
FLUENT versions ... Gautam FLUENT 3 November 1, 2007 10:49
Run Fluent in batch mode Shengping LUO FLUENT 2 October 24, 2000 05:42
