heat transfer
Old   May 24, 2009, 12:45
Exclamation heat transfer
SIVALINGAM
sivam is on a distinguished road
Hi everybody,
We are doing a project in model a liquid based thyristor cooling for this we have many channels of 0.5mm in thickness both solid fins and channel for flow, the problem is we cant mesh these small sizes with unstructured mesh and we also have problem in heat transfer that is ,Do we have to face connect for each channel and fin? thanks in advace
sivam is offline   Reply With Quote
Old   May 25, 2009, 08:35
Ralf Schmidt
Ralf Schmidt is on a distinguished road
Hi!!
I don't really get your geometry...
But one thing, I can tell you: your geometry has to be consistent. That means, the the fluid areas have to be connected.
If the geometry is to complicated, you might divide your model into several sub-models (if there is no (or no big) coupling between them).
You can take the results from one channel simulation as a BC for the other parts simulation...
Best wishes
Ralf
CFD - nothing but Colourful Fluid Dynamics
Ralf Schmidt is offline   Reply With Quote
Old   June 18, 2009, 09:15
SIVALINGAM
Originally Posted by Ralf Schmidt View Post
Hi!!
Best wishes
Ralf
Thanks for ur reply
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
CFX Heat Transfer RJamison CFX 0 July 24, 2008 12:11
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 09:25
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
