Saving *.cas and *.dat from Fluent parallel version
Old   August 14, 2009, 14:07
Default Saving *.cas and *.dat from Fluent parallel version
Pfalcon is on a distinguished road
I am experiencing problems when I'm saving the case and data file from the parallel version (FLUENT6.3). These files are incompatible with Tecplot360. When I load the case into the serial version of FLUENT and resave it, Tecplot reads them just fine.
Same problem when I use FILE-EXPORT function to create Tecplot files from the parallel version. The files are almost always corrupted.
Does anyone have a fix for this?
Many thanks in advance
Pfalcon is offline   Reply With Quote
Old   August 14, 2009, 14:43
Sean Delfel
delfel is on a distinguished road
Hi Pfalcon,
I'm having trouble getting my data into tecplot from Fluent 6.2 parallel, also. I did some looking on the fluent website and found the export to tecplot function from the parallel solver is new in version 6.3, so it may be buggy. Actually, from my personal experience, I've found the 6.3 parallel solver to be "temperamental" to the point that I still use 6.2.
Loading the files into the serial solver and resaving them sounds like a great fix to me, even if it's a hassle.
Cheers,
-sean
delfel is offline   Reply With Quote
Old   August 14, 2009, 14:57
I would not mind doing this for steady calcs. But unsteady this is a real problem. My cases take 15 min to read in, then I need to save and repeat this for 48 time steps. I need to solve this somehow. Any idea if this is related to the partitioning?
fluent, parallel, saving
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 09:32
Fluent parallel poovanna FLUENT 0 March 23, 2007 23:22
error parallel fluent session Diet FLUENT 2 January 27, 2005 12:31
Parallel version of SIP ? Ravikanth Avancha Main CFD Forum 1 March 19, 1999 14:21
