periodic boundary condition in LES
Like Tree2Likes
  • 1 Post By martor
  • 1 Post By LuckyTran
Old   September 4, 2009, 06:36
Default periodic boundary condition in LES
Maria Torres
martor is on a distinguished road
Hey,
I am currently performing LES for turbulent channel flow at a reynolds number of 10935 using FLUENT. I have two questions:
- Can i specify in FLUENT periodic boundary condition in streamwise and spanwise simultaneously ? How can i do this?
-Can I specify the shear stress as wall boundary condiction with the periodic pressure gradient in the streamwise direction?
Thanks in advance
Marķa
jzc likes this.
martor is offline   Reply With Quote
Old   April 9, 2012, 20:28
Negin Nazarian
nenazarian is on a distinguished road
Hi
I was wondering if you found the answer to your first question.
Thanks
Negin
nenazarian is offline   Reply With Quote
Old   April 10, 2012, 19:17
Lucky
You can do periodic boundary conditions in streamwise and spanwise conditions simultaneously. It is possible, I have done this. It is straightforward. Just make the planes periodic (you need to do this using the TUI, it cannot be done with GUI commands).
I do not think that specifying the wall shear stress is appropriate, especially for LES. You would need to know the local wall shear stress everywhere on the walls and apply that as a boundary condition through UDF (which means you would have to already know what the flow looks like, which means that you have already solved your problem, which means that you do not need to do any LES).
villager likes this.
Old   April 30, 2022, 00:20
Tom O
OYYO is on a distinguished road
Hi
I was wondering if you make the planes periodic by using the TUI,can streamwise and spanwise conditions set flow rate or pressure drop respectively?
Thanks in advance
OYYO
OYYO is offline   Reply With Quote
Periodic boundary condition in 2 directions arash FLUENT 21 July 25, 2018 12:44
Periodic Boundary Condition Q symkimon COMSOL 0 May 14, 2009 23:54
Periodic Boundary Condition doug Main CFD Forum 1 April 14, 2009 19:05
periodic boundary condition? Sima Baheri Phoenics 3 July 7, 2006 03:48
settign periodic boundary condition ayapan FLUENT 3 March 14, 2006 10:24
