Master node in parallel computing only distirubtion |
September 8, 2009, 14:26 |
Sayros yadgar
Rep Power: 16 |
I am a bigginer and need some help to run my mesh on parallel processors on one Solaris machine and I remember seeing something about how to fore the master node to only host the distribution of processing and not participate in the processing to avoid overloading the host node. Does anyone know what is this code?
September 8, 2009, 16:41 |
Ivan
Rep Power: 17 |
it seems to me you do not have to write any specific code to make the host node not participate inthe processing. you can check the fluent 6.3.26 user guide page 31-2.
below is the node distribution in one of my cases (nodes=4pn=5) , there is host node and it is not a compute node. ------------------------------------------------------------------------------ ID Comm. Hostname O.S. PID Mach ID HW ID Name ------------------------------------------------------------------------------ n19 hp scw-018 Linux-64 29215 3 19 Fluent Node n18 hp scw-018 Linux-64 29214 3 18 Fluent Node n17 hp scw-018 Linux-64 29213 3 17 Fluent Node n16 hp scw-018 Linux-64 29212 3 16 Fluent Node n15 hp scw-018 Linux-64 29211 3 15 Fluent Node n14 hp scw-016 Linux-64 7680 2 14 Fluent Node n13 hp scw-016 Linux-64 7679 2 13 Fluent Node n12 hp scw-016 Linux-64 7678 2 12 Fluent Node n11 hp scw-016 Linux-64 7677 2 11 Fluent Node n10 hp scw-016 Linux-64 7676 2 10 Fluent Node n9 hp scw-014 Linux-64 2082 1 9 Fluent Node n8 hp scw-014 Linux-64 2081 1 8 Fluent Node n7 hp scw-014 Linux-64 2080 1 7 Fluent Node n6 hp scw-014 Linux-64 2079 1 6 Fluent Node n5 hp scw-014 Linux-64 2078 1 5 Fluent Node host net scw-013 Linux-64 15365 0 3 Fluent Host n4 hp scw-013 Linux-64 15873 0 4 Fluent Node n3 hp scw-013 Linux-64 15872 0 3 Fluent Node n2 hp scw-013 Linux-64 15871 0 2 Fluent Node n1 hp scw-013 Linux-64 15870 0 1 Fluent Node ------------------------------------------------------------------------------ ID Comm. Hostname O.S. PID Mach ID HW ID Name ------------------------------------------------------------------------------ n0* hp scw-013 Linux-64 15869 0 0 Fluent Node |
License server not visible from master node | Charles | FLUENT | 0 | October 30, 2007 17:48 |
Diffusion equation solved using Parallel Computing | Sachin Paramane | Main CFD Forum | 0 | June 11, 2007 23:48 |
Full Fluent license required for the master node? | Paul | FLUENT | 1 | September 1, 2006 04:26 |
Parallel Computing | peter | Main CFD Forum | 7 | May 15, 2006 09:53 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
