Liscense per core or per proceoosr
Old   October 21, 2009, 15:07
Default Liscense per core or per proceoosr
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Hi all
I have some confusion regarding Fluent parallel process.
If we have a single CPU with quad cores it means we have 4 cores. So do we need a single parallel license for that or for separate licenses (each for each core)
Secondly, if I have 8 cores and I give the command fluent 3ddp -t9 it still shows me 9 nodes but technically speaking it should not show that because of physical 8 cores.
Shamoon Jamshed is offline   Reply With Quote
Old   October 22, 2009, 01:57
-mAx-'s Avatar
Maxime Perelli
I suppose you need a license per core (need to be confirmed).
Second guess, I assume you can enforce more process on a core
Old   October 22, 2009, 11:31
Matthew
mbeals is on a distinguished road
The way I understand it from the documentation is that you need one license for every core. However, I have run it on 8 cores of a cluster with only a 4 seat license, and a process check confirmed that it actually had 8 processes running on 8 different cores.
So you may just have to try it and watch the process tree.
mbeals is offline   Reply With Quote
Old   October 23, 2009, 22:50
alven
alven299 is on a distinguished road
From what I understand, if you have 4 cores, you can run your case using 8 nodes.
alven299 is offline   Reply With Quote
4 core & 8 core: same 64bit XP, Xeon, x5570, 2.93GHZ leeruoyun CFX 4 August 19, 2009 00:47
Serial Job Jumping from Core to Core Will FLUENT 2 August 25, 2008 14:21
4 (one core) or 2 (double core) processors? Gen CFX 9 February 21, 2008 05:48
Questions about CPU's: quad core, dual core, etc. Tim FLUENT 0 February 26, 2007 14:02
