October 22, 2009, 13:34 |
incorrect flow pattern
Rep Power: 16 |
hello,
I am simulating a pulsating flow through a pipe. I am using a udf file for the pressure. When I run the display --> pathlines to see the flow pattern it is pulsating but the flow starts at two different points; in the middle and at the right side (inlet). I would like it to be pulsating from just the inlet. |
Target Mass Flow Rate | Nitin | FLUENT | 9 | June 17, 2017 10:30 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
Boundary Layer Flow Paradox | Wen Long | Main CFD Forum | 3 | September 24, 2002 08:47 |
The Effect of impeller type on flow pattern | lee ji hyun | Main CFD Forum | 1 | January 26, 2000 08:35 |
