November 3, 2009, 02:00 |
Much Difference on my airfoil simulation
teguh hady
Hi All,
I'm simulating 2 kind of turbulance model on an airfoil, i.e K Epsilon & SST. but there is much differences. I dont know where is my fault!! Help me out this problem, Thanks teguhtf P.S. I attach the report and figure of each turbulence condition Last edited by teguhtf; November 3, 2009 at 02:49. |
November 16, 2009, 12:21 |
Felipe Gutiérrez Donoso
It doesn´t look good to me, how are the residuals??
November 21, 2009, 20:04 |
teguh hady
Hi Figd84
Thanks for your reply. my simulation has converged on iteration. Btw, How i can see convergence on residual graph?? Because I think if the solution has converged, i ignore the residual. Thank You teguh PS. I'll Post my residual graph later
Now Or Never!!! |
November 23, 2009, 00:51 |
Maxime Perelli
Rep Power: 41 |
From your pictures I can't see any outlet (I see only a blue edge which means inlet).
If I am right, then it might be your error, since you don't have mass conservation
In memory of my friend Hervé: CFD engineer & freerider |
December 4, 2009, 06:43 |
teguh hady
I'm sorry to be late on the reply. I've focused on my fabrication on the turbine for a while.
Yes, You are right. I use wrong BC.^^ I've tried some of type of BC and take a note on it. Now, I'm still working by up & down wall (free slip) and the inlet is velocity inlet & outlet is press outlet. thank's teguhtf
Now Or Never!!! |
Comparison the airfoil 0012 experimental result and simulation result | harrislcy | FLUENT | 30 | August 29, 2013 10:27 |
dynamic stall simulation over an airfoil | mleahy | FLUENT | 0 | October 9, 2009 12:15 |
ICEM CFD Airfoil Tutorial Input | Tom | ANSYS Meshing & Geometry | 1 | September 25, 2009 06:50 |
simulation of airfoil at high AOA | hsnu84053 | FLUENT | 0 | January 26, 2007 21:34 |
Simpliest way to run airfoil simulation diff AOA | Ben | FLUENT | 0 | November 19, 2006 02:11 |
