Much Difference on my airfoil simulation
Old   November 3, 2009, 02:00
Question Much Difference on my airfoil simulation
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Hi All,
I'm simulating 2 kind of turbulance model on an airfoil, i.e K Epsilon & SST. but there is much differences. I dont know where is my fault!!
Help me out this problem,
Thanks
teguhtf
P.S. I attach the report and figure of each turbulence condition
teguhtf is offline   Reply With Quote
Old   November 16, 2009, 12:21
Felipe Gutiérrez Donoso
Figd84 is on a distinguished road
It doesn´t look good to me, how are the residuals??
Figd84 is offline   Reply With Quote
Old   November 21, 2009, 20:04
Red face
teguhtf's Avatar
teguh hady
Hi Figd84
Thanks for your reply. my simulation has converged on iteration. Btw, How i can see convergence on residual graph?? Because I think if the solution has converged, i ignore the residual.
Thank You
teguh
PS. I'll Post my residual graph later
Now Or Never!!!
Old   November 23, 2009, 00:51
-mAx-'s Avatar
Maxime Perelli
From your pictures I can't see any outlet (I see only a blue edge which means inlet).
If I am right, then it might be your error, since you don't have mass conservation
Old   December 4, 2009, 06:43
Cool
teguhtf's Avatar
teguh hady
I'm sorry to be late on the reply. I've focused on my fabrication on the turbine for a while.
Yes, You are right. I use wrong BC.^^
I've tried some of type of BC and take a note on it.
Now, I'm still working by up & down wall (free slip) and the inlet is velocity inlet & outlet is press outlet.
thank's
teguhtf
Now Or Never!!!
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 10:27
dynamic stall simulation over an airfoil mleahy FLUENT 0 October 9, 2009 12:15
ICEM CFD Airfoil Tutorial Input Tom ANSYS Meshing & Geometry 1 September 25, 2009 06:50
simulation of airfoil at high AOA hsnu84053 FLUENT 0 January 26, 2007 21:34
Simpliest way to run airfoil simulation diff AOA Ben FLUENT 0 November 19, 2006 02:11
