Meshing airfoil
Old   April 19, 2000, 08:51
Default Meshing airfoil
Wason
Hi,Dear All
I am using FLUENT5 to simulate the unsteady flow of 2D airfoil & 3DWing,but I meet a problem when I model 2D airfoil mesh, I don't know how to control the mesh density near the wall by using structure mesh(quad Map method). Is it possible for Gambit to model structure mesh? and How? I don't know why I could not transfer boundary layer generated by Gambit to Fluent 5? Is there any technique?
Thank you in advance! If it is possilbe, Please give me a copy via email when you responce. Thanks
Old   April 19, 2000, 21:33
Default Re: Meshing airfoil
yin jaafar
hi! if i'm not mistaken, fluent 5 only accepts unstructured mesh, but then, check again.
Old   April 19, 2000, 22:06
Wason
Thanks for your response, Gambit can creat a mapped mesh. and it can be transfered to Fluent5. But I don't know how to generate a suitable mesh around airfoil, especially near the wall. I have tried to divide the computational domain into three blocks, and then mesh them resepectively with quad map method.The edges except airfoil wall and far wall were set as interior boundary condition ,However, when I use this mesh in Fluent5 to solve (Mach=0.6/AOA=0) a problem, I could not get a resonable result(Vmax exceed 400m/s), was wrong with me?
Thanks Wason
Old   April 25, 2000, 21:01
Balaji Vasudevan
I think that you can create boundary layers attached to the aerofoil wall and extending to a suitable distance. This will take care of the mesh density near the wall.
- Balaji
Old   April 25, 2000, 21:48
Wason
Thank you for your response, Yes, I have tried to create boundary layers attached to the aerofoil wall and extending to a suitable distance. But I don't know why I couldn't transfer the boundary layer mesh from Gambit(Version1.1) to Fluent,It only leaves the normality mesh. Could you tell me the process of meshing a airfoil with boundary layer?
Thanks a lot!
Wason
Old   April 26, 2000, 16:05
Aaron J. Bird
I believe that the important things to keep in mind are the direction of your boundary layer, the depth, and the growth factor. The direction and depth you will know from working with the problem and having a feel for the grid resolution necessary to capture the boundary layer. The growth factor should not exceed 15%... like something between 1.01 and 1.15. You probably already know this, but you must mesh the boundary layer first before the rest of the mesh.
Old   November 8, 2009, 11:50
Fariborz Soroush
faudiS8 is on a distinguished road
hi all
thanks for your attention
I wanna to create a structured grid around an slotte flp section with the limitation of 10000elements and the angle of flap of45 degrees. so I wanna know what's your idea?(also I work with Gambit)
My initial idea is to connect to parts together then mesh around like an airfoil then mesh inside .....no idea again generated till know!(I'm sleeepy!)
faudiS8 is offline   Reply With Quote
Airfoil Meshing Scheme in Gambit J. Weiler FLUENT 6 October 2, 2011 15:41
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 00:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Oscillating Airfoil - Dynamic meshing or user-defined velocity profile. DarrenC Main CFD Forum 5 July 19, 2010 22:33
[GAMBIT] Meshing airfoil using .dat file problem creggie ANSYS Meshing & Geometry 10 June 27, 2010 19:24
