Is there a way to write the time step size, time a
Old   December 5, 2003, 02:40
Default Is there a way to write the time step size, time a
may
Hi, I am doing an unsteady flow simulation with adaptive time step. Although we can monitor the time step size and time using "Statistic Monitors", the data are stored in the individual data file. To know the corresponding time step and time for each data file, we shall read every data file. Therefore I am wondering that is there a way to write the time step size and time associated with data file no. in one file, such as if we monitor the inlet flow rate at every time step, we can get the flow waveform? I do need your help. Thanks a lot!
Old   December 5, 2003, 03:49
Default Re: Is there a way to write the time step size, ti
ccc
hi may,
you can inlude "%t" in the file name in the autosave panel and this string will be converted to physical time when saving.
good luck.
Old   December 5, 2003, 04:22
may
Hi, Mr./Ms. Chen,
Thanks for your kindly suggestion! I will try it and let you know the results soon. Best Regards,
Old   December 5, 2003, 07:25
Default "%t"seems only represent the time step no.
may
Dear Mr./Ms. Chen,
I have done it acoording to ur sugestion.However the data files still named as the time step no., not the true time. Can u give me some further suggestions? Thanks a lot!
Old   December 6, 2003, 10:19
Default Re: "%t"seems only represent the time step no.
ccc
hi may,
You are right. I misunderstand your meanings. sorry for wrong suggestions.
An easy way to solve your problem is to record the timestep and the corresponding physical time in a seperated file. Then you can look up this file after computing and know the physcial time of each data file. N_TIME will give you the time step and CURRENT_TIME the physical time.
Good luck.
Old   December 8, 2003, 05:09
Default thanks a lot
may
Dear Mr./Ms. Cheng,
Thanks for your kindly suggetion! I have compiled a UDF to do this kind of work. It works sucessfully.
Thanks a lot!
Best Regards
Old   November 22, 2009, 11:52
Smile
Shengyi Wang
gmwsy is on a distinguished road
Not %t, but %f !!!
gmwsy is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Time step, Number of time step, Maxximum Iterations per time step sandisk FLUENT 0 July 18, 2011 02:57
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
