negative temperature problem
Old   November 25, 2009, 18:31
Default negative temperature problem
Renold is on a distinguished road
I am simulating a 2D turbomachinery with the laminar model. The negative temperature keeps occuring. But it is only in a small portion of one cell so Fluent still can proceed until non-positive volumes is found. Did anyone happen to experience this issue before?
Best regards,
Renold
Renold is offline   Reply With Quote
Old   November 27, 2009, 14:41
karine
thecfduser is on a distinguished road
Hi
Are u using QUICK? can give overshoots and undershoots
thecfduser is offline   Reply With Quote
Old   November 28, 2009, 15:03
Thank you. I am using PISO method. And I figured out the non-positive volume issue was because of my interface setting.
help,why the negative energy source does'nt make the temperature decrease, thank you! hunter FLUENT 6 May 12, 2010 17:39
Negative Density problem in starcd Dinesh Siemens 4 January 26, 2009 12:53
Negative density problem. compressible flow Karl Siemens 2 July 10, 2008 16:41
Negative Volume Problem Alicia Siemens 1 July 27, 2005 07:05
Negative densities found ina an I.C engine problem varun Siemens 5 June 2, 2005 02:03
