Heating of a metal piece in a furnace
Old   December 6, 2009, 05:42
Unhappy Heating of a metal piece in a furnace
Paul
Paulik is on a distinguished road
Hello everyone,
I am trying to view the heating profile of a metal piece within a furnace using Fluent. I've built the geometry in Gambit and now I wanna solve this problem in Fluent but I have a problem: it doesn't work. I can see the heating profile in the furnace and I can see that the metal piece is disturbing the "natural" flow, but I cannot see the profile inside it (no conduction). Does anyone have any idea how to "activate" conduction or how to include that piece in the calculus ?
Paulik is offline   Reply With Quote
Old   December 7, 2009, 01:28
Johann V
JohannV is on a distinguished road
Hi Paulik,
Did you choose the solid property for your metal piece?
And did you selected the coupled option in the wall between the fluid and the metal piece?
JohannV is offline   Reply With Quote
Old   December 7, 2009, 08:55
Default Heating of a metal piece in a furnace
Paul
Yeah, I set all the properties. I also have the wall set to coupled. Look, uploaded a photo with the boundary conditions. Maybe the geometry isn't good. I don't know why it isn't working. The flow near the metal piece is deviated but the temperature inside in constant.
As you can see, the metal piece is neutral.
Old   December 7, 2009, 09:41
Johann V
I did a mistake last week. May be you have the same one. In my case I expected a clear temperature distribution, but because of the different heat capacities the temperature distribution was vely smooth inside of my metal pice.
Please try to plot the temperature distribution from the wall of the metal pice to several milimeters inside. May be it helps.
If you allredy done this, I have no other sugestions.
Good luck
Old   December 7, 2009, 09:48
Paul
( I've already done this. I have made a XY Plot (Temperature vs Lenght inside the body) to see if there is any heat at the boundary but nothing and I also changed the thermal conductivity coefficient for the metalic piece with a value closer to the one of the fluid.
Thanks a lot Johann for trying to help me.
If maybe there are any other person that could help me?
Old   December 8, 2009, 02:36
Johann V
Hi paulik,
whats about your y+ value. I read in a anothe forum that this value should be between 1 and 3.
Old   December 8, 2009, 07:58
Paul
Where can I see the y+ value?
I know about the Yplus of the turbulence model but only for plotting and its value is 0 constant.
Old   December 8, 2009, 09:16
Johann V
You can find it in:
Display->Contours->Contours of: Turbulence and Wall Yplus
Old   December 8, 2009, 09:18
Paul
Yeah, that one is 0. I have nothing inside. Any suggestion ?
Old   December 8, 2009, 09:43
Johann V
As I understood, you have only buoyant flow. Do you consider the gravity and the temperature dependent density?
Old   December 8, 2009, 09:45
Paul
Nope. No gravity and no temp-dens dependence
Old   December 8, 2009, 09:49
Johann V
I'm not shure, but could you post a picture with your mesh at the wall?
Old   December 8, 2009, 09:56
Paul
Old   December 8, 2009, 10:05
Johann V
I think it has somethink to do with der wall funktion(boundary layer).
If you look at the exuiations of the heat transport (fluent documentation), and the exuiation of y+, there is alwais a term for turbulenc. And if you have only boujant flow, may be there is no turbulence.
Old   December 8, 2009, 15:00
Johann V
Hi I just calculated your case and there was the same problem, no heat flux to the metal piece. But after a patch of the turbulent kinetic energy there was a heat flux.
So I think you need some turbulence to transfer the heat.(see the equations in fluent documentation)
I think you can solve the problem with a UDF.
Please let me know if you have successful calculated the case.
Old   December 9, 2009, 06:26
Paul
First of all I want to THANK you so much for helping me and secondly I think I'm screwed up in the head. It doesn't work to me. I Initialize the Turbulent Kinetic Energy Patch to the both interiors but I see no changes. I think I did something wrong from the beginning.
Let me tell you what I defined and maybe you can see the problem from this, if it worked for you.
So, I defined the following:
Boundary Conditions:
  • big_interior(inside the furnace) - Interior - Fluid - No source terms and fixed values;
  • small_interior(inside the metallic body) - Interior - Solid - No source terms and fixed values;
  • up/down walls - Wall - Temperature (300K);
  • metallic_walls - Wall - Coupled;
  • metallic_walls_shadow - Wall - Coupled;
  • left/right walls - Wall - Heat Flux 10 W/m2 and HGR 10W/m2
Models: Energy Ecuation Activated
Viscous: Viscous Heating Activated + Viscous Model K-epsilon
Materials: Aluminum (solid) and Air (fluid)
and the Initialization from the left/right walls.
This is what I am using. If you think something's not right, please let me know.
Once again,
Thanks a lot dude for helping,
Paul
Old   December 9, 2009, 07:44
Johann V
hi,
i have the same BC's and additionaly I activated the gravity. I also use temperature dependent density and heat capacity of the air.
But this is not the problem, the velocity distribution on the fluid seems to be physical allright.
I used the laminar solver, because there is no turbulence in the computational domain.
The question is: how is the heatflux calculatet in a laminar case?
I'm now trying to find it out.
Old   December 9, 2009, 08:36
Piotrek is on a distinguished road
I was reading your post and I do not understand one thing. In your geometry you have heatflux on side walls. Top and bottom walls are set to 300K - constant temperature. Up to this point it is ok.
Than you define all walls of the box to be 300K. If this is a boundary condition, than the surface will simply cool the fluid around, and that is what I see on the picture.
I think that you should set this side wall of the box with zero (0) heatflux instead of temperature condition. Maybe specify tempeature at the bottom of the box, than you should have heat transfer in solid. Correct me if I am wrong. Good luck
Piotrek is offline   Reply With Quote
Old   December 9, 2009, 10:35
Unhappy Still not working
  #19
Paul
Now the walls of the metallic body are set to Coupled and 0 on Heat Generation. I also set the Laminar Solver.
I now have this profile:
Which is also abnormal because now I have constant temperature inside the body. This is a messed-up problem.
Another strange thing is the temperature profile inside. Take a look at this XY Plot:
I understand something happens there. I have a temp. drop on the down corners of the body.
Oh, and I also included the Gravity (y=-9.81) as Johann recommended.
Old   December 10, 2009, 06:36
Johann V
Hi Paulic,
I yust calculated your problem again and I have some good results.
I have a heatflux through the aluminum wall and the temperature is slowly inkreasing. We were to impatient, the result apears after some xK iterations.
Now its up to you to evaluate the physiks of the modell.
Give me your e-mail and I will send you the case file.
conducion, convection, furnace, gambit, metal
Heating of a metal piece inside a furnace CFDguy FLUENT 2 September 5, 2008 08:41
Model flow over / through expanded metal walkways. andy2o CFX 5 January 11, 2008 04:13
tubular furnace design Jason FLUENT 0 October 20, 2007 23:28
Furnace curtains Marc FLUENT 0 April 18, 2007 08:01
Inclination of the furnace Clif CFX 1 October 4, 2006 05:48
