January 6, 2010, 08:34 |
L-shaped duct
Sebastian Gatzka
Rep Power: 20 |
Hello world.
I'm trying to simulate the flow in an L-shaped duct. See the picture attached. I'm using velocity-inlet and outflow as boundary conditions. The rest are walls. Unfortunately the case does not converge. Residuals are stuck at some level. On what does the convergence of such a case depend? Any ideas?
Schrödingers wife: "What did you do to the cat? It's half dead!" |
January 6, 2010, 09:42 |
Svetlin Filipov
First of all try to remesh the domain...as I see it is a bit of luck that you got constant residuals..... and.... I do not know the dimensions of the pipe, but..... outflow BC assumes fully developed flow... (for good results)
January 6, 2010, 10:55 |
#3 | |
Sebastian Gatzka
Rep Power: 20 |
Dimensions are 1m x 1m cross-section, with 10 meters overall-length.
January 6, 2010, 12:46 |
Svetlin Filipov
yes, refine the mesh, take into account the inlet BC (velocity, Re, adequately calculate the equivalent diameter, fluid type and so on)...
S shaped duct | francois | Main CFD Forum | 5 | May 16, 2014 05:44 |
Fabric Duct Modeling | Dan | FLUENT | 0 | June 30, 2008 15:00 |
Total pressure increase in the diverging duct | shiv | Siemens | 3 | February 1, 2008 03:39 |
modelling fuel cell duct in fluent | rajesh kumar tippabhotla | FLUENT | 2 | October 7, 2004 12:04 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
