L-shaped duct
Old   January 6, 2010, 08:34
Default L-shaped duct
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello world.
I'm trying to simulate the flow in an L-shaped duct.
See the picture attached.
I'm using velocity-inlet and outflow as boundary conditions.
The rest are walls.
Unfortunately the case does not converge.
Residuals are stuck at some level.
On what does the convergence of such a case depend?
Any ideas?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   January 6, 2010, 09:42
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
First of all try to remesh the domain...as I see it is a bit of luck that you got constant residuals..... and.... I do not know the dimensions of the pipe, but..... outflow BC assumes fully developed flow... (for good results)
Philipov is offline   Reply With Quote
Old   January 6, 2010, 10:55
sega's Avatar
Sebastian Gatzka
Remesh? I guess I should create a finer mesh?
Dimensions are 1m x 1m cross-section, with 10 meters overall-length.
Old   January 6, 2010, 12:46
Philipov's Avatar
Svetlin Filipov
yes, refine the mesh, take into account the inlet BC (velocity, Re, adequately calculate the equivalent diameter, fluid type and so on)...
S shaped duct francois Main CFD Forum 5 May 16, 2014 05:44
Fabric Duct Modeling Dan FLUENT 0 June 30, 2008 15:00
Total pressure increase in the diverging duct shiv Siemens 3 February 1, 2008 03:39
modelling fuel cell duct in fluent rajesh kumar tippabhotla FLUENT 2 October 7, 2004 12:04
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
