filling cylinder
Old   January 15, 2010, 04:55
Default filling cylinder
Farshad
f_panahizadeh is on a distinguished road
i'm investigating about CFD simulation of filling a cylinder.
I consider asymmetric, unsteady, compressible, turbulent flow, real gas.
When I consider the pressure inlet boundary condition and applied variation of it by using a UDF the flow after about 10 second diverged. I think it caused by the variation of mass flow inlet so how I can control or specify mass flow inlet when use the pressure inlet boundary condition in Fluent?
f_panahizadeh is offline   Reply With Quote
Old   January 18, 2010, 00:41
herntan's Avatar
YH Tan
herntan is on a distinguished road
use mass flow inlet boundary condition.
Pressure inlet is impossible to control the mass flow. pressure and mass flow is inter-related to each other.
Herntan,
Add Reputation if I am right
herntan is offline   Reply With Quote
Old   January 18, 2010, 00:48
Farshad
Thanks for your answer
please clear how i can define the pressure variation by using the mass boundary condition?
thanks in advance
Old   January 18, 2010, 01:31
herntan's Avatar
YH Tan
mass flow rate will automatically create the pressure.
flow always flow from high pressure to low pressure. When u define mass flow rate, the pressure is already there, its impossible to set something which already fixed.
I think u might dealing with something else, please carify ur problem with picture and explain in detail.
Herntan,
Old   January 18, 2010, 03:52
Farshad
i should write a UDF for defining mass flow rate varation via time or not?( the pressure of the inlet flow varied from 1bar to 40 bar in 40 seconds and i'm investigating to find temperature field within cylinder via time)
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 9, 2008 23:02
CNG Fast Filling in a Cylinder Rushaed FLUENT 0 August 19, 2008 09:49
gas cylinder filling Farrukh FLUENT 7 December 2, 2005 10:41
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
