Simulations at different AoA
Old   January 20, 2010, 07:39
Default Simulations at different AoA
ghost is on a distinguished road
I am trying to find out the change of lift coefficient with respect to AoA of an airfoil.
To do this I run the same case but at different Aoa in fluent. All cases start from scratch and iterate till converge.
Today I heard from my friend that I could have run a single case till converge, change the AoA, then continue running that case till converge for new AoA. Will the results be identical and more accurate? This will greatly save a huge amount of time.
Thank you.
ghost is offline   Reply With Quote
Old   January 22, 2010, 09:10
anyone has any idea regarding this?
Old   January 22, 2010, 11:19
DoHander is on a distinguished road
If you use the steady flow solver yeah, you can in principle start from any initial solution. So a wise choice will be to do the calculation for say 0 degree, wait until this case converge.
Start a new case with a different AOA say 2 degree but use as initial solution the solution from 0 degree.
For 4 you will use the solution for 2 as initial solution and so on ...
Do
DoHander is offline   Reply With Quote
Old   January 23, 2010, 10:36
thank you very much...yes im using steady flow solver...thanks for the confirmation.
Simulating flow past airfoil with different AOA ramin FLUENT 4 April 22, 2015 13:09
Timestepping in two - phase Simulations using RSM challenger85 CFX 0 January 4, 2010 05:00
CL vs AOA plot low reynolds difficulties andy_r FLUENT 3 March 25, 2009 09:14
Simulating flow past airfoil with different AOA Quarkz Main CFD Forum 2 January 6, 2006 10:56
URANS and Transient Simulations bob Main CFD Forum 0 October 1, 2003 03:54
