April 15, 2014, 02:32 |
Fluent DPM chemical reaction
Sam
Rep Power: 12 |
Hi everybody
Can anybody help me regarding urea spraying in SCR(selective catalyst reduction) . I used DPM model to simulate urea solution spraying, breaking up of droplets, evaporation, and chemical reaction with exaust gas(continuous phase). However I am faced with questions as follows: 1. The specific meaning of "break up parcels" and so on. 2. The method of defining urea solution as one of material showed in injection panel. If use UDF, how to use it? 3. The custom laws of droplet particle doesn't have chemical reactions. How and where to add chemical reaction with exaust gas? 4. Do I need to use the nozzle model provided by fluent itself or set a model defined by myself? Thanks |
April 21, 2014, 10:50 |
#2 | |
shoeb khan
Rep Power: 14 |
I hope i may answer some of your queries. 1) Breakup means how many parcels are been breake up based on the instabilities that re in the flow. You may change the parameters of the breakup models primary or secondary and fine tune the amount of the particles being break up. 2)Just use the default material panel and provide the properties of urea there. Then use that urea in the DPM model. 3) I have no idea about it but i think there should be option of reactions in DPM. 4)Use the default models in fluent. Just fine tine them depending upon your injector. Regards shk |
April 23, 2014, 01:55 |
DPM chemical reaction and parcels
#3 | |
Sam
Rep Power: 12 |
I am also doubt about the your answer about "particle parcel". How can I edit the amout droplet contained in one parcel ? Regards |
chemical reaction, dpm, udf |
What's the unit of heat of reaction in Fluent??? | yerem3 | FLUENT | 1 | December 26, 2019 05:17 |
chemical reaction modeling using FLUENT | wlt_1985 | FLUENT | 6 | April 16, 2014 07:45 |
chemical reaction in Fluent | h.soltani | Fluent Multiphase | 0 | November 24, 2013 16:28 |
DPM with reaction (a simple question) | lili | FLUENT | 0 | November 28, 2011 03:52 |
about defining chemical reaction | Kim | FLUENT | 1 | October 17, 2004 09:56 |
