February 24, 2010, 08:35 |
define a water-salt solution in fluent
Hi everybody
does anybody know how to define a water-salt solution in fluent? thanks |
February 26, 2010, 08:10 |
chétan
hello,
to define salt-water solution, You need to select fluid species Water [H2O(l)]. Then, you need to create pseudo species named Salt, with similar properties. Now, create Mixture named Solution, then add water and salt in as species. Now, to adjust % of salt in the solution you need to specify H2O value in the solution panel by 'patch'. i hope, this will be helpful to set up Salt-water solution. regards Chetan |
February 27, 2010, 03:45 |
thanks a lot
u solve my problem |
January 26, 2012, 05:31 |
george
hello,
I have already had the same problem. Could you help me How I can define water-salt solution for fluent. I havent understood the procedure below. Pls HELP ME!!! |
February 11, 2019, 09:20 |
Defining salt
#5 | |
Sepehr Mostafayi
Hello I dont know how to define salt as a material in fluent, may you help me with that? thanks |
February 12, 2019, 09:39 |
Roland Janoyan
Rep Power: 7 |
Define as mixture !!!
February 12, 2019, 10:32 |
Sepehr Mostafayi
Hi
Thanks for your answer,I knew I should define a new mixture with the species of salt and water, before that I have to define salt as a fluid, is it right? |
February 13, 2019, 00:26 |
Roland Janoyan
Rep Power: 7 |
I think you will define as fluid, but I'm not sure, do some research. But you need define mixture density and if in your case energy is turned on, define liner dependence of density on temperature.
how to define a mixture in FLUENT | wildli | ANSYS | 4 | January 24, 2021 17:42 |
Particle Tracking - Can't define water particles | CFDLife | CFX | 2 | October 3, 2008 06:12 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
