March 9, 2010, 06:51 |
VOF Model or Mixture Model
Rep Power: 16 |
Hi guys,
I'm modelling a valve with cavitation. The valve at the beginning is full of air. So i have two mixture of fluids: water-vapor and water-air. For cavitation, i've read Mixture Model is better but for water coming in a control volume with air, VOF Model suits better. How would you do it with the same model for both situation?? Also, better transient or steady analysis?? cause the problem is that air never dissapears in the valve as it is to get water out of a dam, the suction of air is quite high. Any ideas??? |
March 9, 2010, 10:31 |
cav modeling
#2 | |
If you are doing cav modeling ...always go for mixture approach. Dont worry about the air..it wont predict cavitation in the air regions. The liquid-air interface may be smeared since its a mixture approach ..but we dont need that sharp interface (right?)..Steady unsteady both should be ok ..but for actual process itself...valve type..run unsteady to capture more transient effects.
/CFDtoy Quote:
CFDtoy |
March 9, 2010, 10:37 |
Rep Power: 16 |
Thanks man!!!!
I will give a try the way you say. I'm just scared that air can influence where cavitation happens. I'll let you know, if you don't mind. C ya. |
cavitation, mixture, vof |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
plz rply urgent regrding vof model for my system | garima chaudhary | FLUENT | 1 | July 20, 2007 08:37 |
urgent query regarding vof model plz rply | Garima Chaudhary | FLUENT | 0 | July 13, 2007 02:20 |
evaporation multiphase model ( vof? mixture ? ) | emanuele | FLUENT | 0 | March 2, 2007 11:44 |
about VOF model | rey | FLUENT | 5 | August 13, 2002 06:02 |
