HELP please!!! ''note: separating wall zone into zones..'' - Import from ICEM
Old   November 16, 2010, 18:04
Default HELP please!!! ''note: separating wall zone into zones..'' - Import from ICEM
Catthan is on a distinguished road
Dear all,
I am modelling conjugate heat transfer from combustion process in a burner and when I import from ICEM, fluent 12 creates the coupled walls but separates some of them in other zones eg.
''separating wall zone 1_1 into zone 1_1 and zone 1 0.59''
most of the created zones are just a few cells or triangles..
I have a fluid volume region and a few solid regions for CHT.
Can you please tell me why this happens and how can I solve it?
It had happened to me in the past but I improved the mesh which now passes all the checks from ICEM but the wall separation happens in more walls than it did in the past..
Any ideas?
Thanks in advance
Catthan is offline   Reply With Quote
Old   December 10, 2010, 16:10
jpo
jpo is on a distinguished road
I have the same problem with one of my cases
jpo is offline   Reply With Quote
Old   December 13, 2010, 04:52
Hi jpo,
I think I found the problem although have not managed to solve it 100%
So (at least for my cases), the separation happens either when there are surface elements that do not capture a surface or when then there are surfaces shared by two different parts.
The latter might be reasonable although there may be problems when setting BOCOs.
I haven't found a way to deal with that yet..
The bad surface elements can be eliminated by re-meshing and being careful when setting mesh sizes for each surface.
These are the causes of my problems and might not apply in your cases.
All the best
Old   December 13, 2010, 08:01
jpo
thank you
I found out when I cut volumes with a face and then introduce interior and wall faces as needed, the problem in fluent disappears.
It is much more work in gambit to do it that way though
Old   December 13, 2010, 13:12
TDi
Tim Diller
TDi is on a distinguished road
I have had this same issue when importing from GAMBIT. In particular, when disconnected faces of a zone are imported, Fluent creates new wall zones. Dealing with the resulting setting of BC's is tedious, so I avoid changes to the mesh or I try to automate them with a script.
TDi is offline   Reply With Quote
Specifying nonuniform initial condition msyaml OpenFOAM Running, Solving & CFD 65 April 25, 2016 04:23
Elements that limit the Courant number skabilan OpenFOAM Running, Solving & CFD 9 July 3, 2008 12:07
Error: access: unbound variable,HELP sudhakar FLUENT 0 January 15, 2007 23:21
export gambit-unbound variable ernie FLUENT 0 August 6, 2006 18:33
import mesh error/warning Laxminarayana FLUENT 1 February 15, 2005 08:49
