Fluent Simulation time windows 7 64
Old   December 8, 2011, 19:11
Default Fluent Simulation time windows 7 64
Nathan
natantyt is on a distinguished road
Hi There
I would like to ask how I can manipulate the memory allocated to Fluent in my system which is Windows 7 64bit with 48 GB RAM. I'm doing serial simulation. Something funny here is that the time required to do this simulation with a windows XP 32bit 4 GB RAM was less than my new system with 48 G RAM. My desktop shows 48GB RAM available.
Thanks,
natantyt is offline   Reply With Quote
Old   December 13, 2011, 16:35
Felix Apel
Don456 is on a distinguished road
as far as I understand it your simulation is using less than 4gb of ram cause one thread on a 32 bit OS can only allocate 2 gb of ram there the amount of ram shouldn't be a problem or a boundary.
Besides the amount of available ram the used processor has quite a huge influence on the speed of the simulation.
Furthermore depending of the cell count of your case it might be faster to use more than one cpu core (on small cases it will get slower cause more overhead between the tasks).
The last thing is if you use a 64 bit version of fluent and which version.
Older versions of Fluent might not run nicely under newer versions of windows.
Hope that might help you
Don456 is offline   Reply With Quote
Adding heat source to chtMultiRegionFoam maddalena OpenFOAM Programming & Development 61 February 17, 2018 08:33
Fluent in Linux vs. Fluent in Windows Melih FLUENT 6 November 16, 2014 09:39
Fluent 12.1 - time dependence of variables in transient simulation hanka FLUENT 6 October 18, 2010 15:43
Can Fluent start a simulation from a negative time Ted Chu FLUENT 10 November 26, 2008 21:06
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
