plot bulk temperature of fluid
Like Tree2Likes
  • 2 Post By Shayan
Old   May 13, 2010, 15:27
Default plot bulk temperature of fluid
mohammad
mohammadkm is on a distinguished road
Dear all
we can get bulk temperature in Report>Surface integrals:change report type from Area to Facet average.
with this way i get bulk temperature in inlet or outlet or...
The problem is how can i plot bulk temperature in x-direction?
There is no bulk temperature in xy plot!!
Is there any way to plot and write bulk temperature in x-direction?
thanks
mohammadkm is offline   Reply With Quote
Old   November 11, 2011, 11:54
Shayan is on a distinguished road
hi mohammad,
there is no direct way to calculate bulk temperature in x-direction,
you may creat some surfaces,then in costume field functions tab(in definition tab) make Velocity*Temperature function,in Report>Surface integrals use integral or sum report(depends on your precision) for both Velocity and your Velocity*Temperature function on each section; by diveiding these two quantity,you will have bulk temperature in each section, then u can use curve fitting for your x-bulk temperature
LuckyTran and Luttappy like this.
Shayan is offline   Reply With Quote
Old   December 9, 2011, 00:05
Shashank
shashank312 is on a distinguished road
Where to create surfaces? At some distances from the wall you mean?
shashank312 is offline   Reply With Quote
Old   December 11, 2011, 09:33
at some distances from inlet, in facet you creat iso-surfaces along the length of your wall, you can use TUI to creat them or u may read a journal file containing the commands to creat all of them at same time,
iso surfaces are cross-sections where you want to calculate bulk properties,so they are perpendicular to your wall
Old   December 13, 2011, 15:37
Shashank
How to create surfaces using TUI or journal file. Please help. The FLUENT text command list does not give any examples.
how to create a temperature dependant fluid Amy CFX 4 October 18, 2009 19:30
Solid Surface and Fluid Results Plot CK FLOW-3D 2 November 12, 2008 00:32
Fluid Vs. Wall Temperature Jack Smith FLUENT 5 January 25, 2006 11:42
Plot temperature vs time for a defined point FREDERIK FLUENT 0 August 26, 2005 05:49
bulk temperature .. Urgent !!! yogesh FLUENT 0 February 22, 2005 00:58
