Two phase flow in a distributor
Old   March 2, 2010, 22:13
Default Two phase flow in a distributor
Mohsin Mukhtar
Mohsin is on a distinguished road
Dear fellows
I am working on Fluent for the simulation of two phase flow (coal plus Nitrogen) in a coal distributor and to get a uniform flow at the three outlets.
Could you please tell me what boundary condition (Pressure outlet, Outlet) or parameter I should give or choose in order to determine that the flow at the outlet would be distributed among the three outlets ( I mean the concentrtaion of the flow would be 33.33 % in each of the outlets, given that the concentration of the inlet is non uniform). Please if its possible for someone please give me a guideline.
Thank you
Mohsin
Graduate student
South korea
Mohsin is offline   Reply With Quote
Old   March 3, 2010, 01:22
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Maybe I didn't understand what you want, but in the BC (multiphase model enabled) you have to specify the VOF of one phase).
So in your case you may set the VOF with the value 0.3333 or 0.6667 depending on your primary phase
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 3, 2010, 01:32
Mohsin Mukhtar
Thank you very much Max for your time.
I am using DPM model. In a coal distributor Pulverized coal is conveyed pneumatically through Nitrogen into a combustion chamber. The three outlets of the coal distributor goes into the combustion chamber.My goal is to get the uniform distribution of coal concentration at the outlets so that it can be burned correctly, given that the inlet has non uniform coal concentration.
Could you please tell me while using DPM model how can i measure the coal concentration at the outlets. can the Pressure outlet boundary condition give me the required result?
Thank you so much.
Mohsin
Old   March 3, 2010, 03:23
-mAx-'s Avatar
Maxime Perelli
you are driving me in a unknown field (DPM)
I can only say that you must specify your concentration (VOF) in outlet and inlet. In other words the concentration has to be known
Old   May 24, 2010, 02:25
Default HI
Srinivas
srinu7257 is on a distinguished road
Is there any material available on this matter??
srinu7257 is offline   Reply With Quote
Old   May 24, 2010, 02:57
Mohsin Mukhtar
Yes. I posted this 3 months ago. Now i think i m a champion of DPM) just kidding.
You can refer to this web page and if u have any querry u can ask me.
http://my.fit.edu/itresources/manual...f/ug/chp22.pdf
Have a good time!
Mohisn Mukhtar
two phase flow
Validation for laminar Disperse phase flow shashwat Main CFD Forum 0 April 4, 2008 02:20
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 16:48
Mass flow of discrete phase at a point dan FLUENT 0 November 2, 2005 10:34
Multiphase flow problem icedou FLUENT 6 July 10, 2005 02:52
Two phase flow in porous media Madhavi Krishnan FLUENT 3 June 6, 2005 05:52
